If you stick with the cheap blue stuff I believe it's only methanol, water, and dye (at least according to the MSDS). The concentration of methanol will probably vary slightly depending on brand, batch, etc, but if you use an accurate hydrometer to mix it to the desired concentration it should be the same as using straight methanol (and a lot safer).
