Washer fluid as ground loop antifreeze?
Last Post 08 Jan 2009 09:29 PM by engineer. 7 Replies.
geoSteveUser is Offline
04 Jan 2009 07:49 PM
I was just visiting friends in Rice Lake Wisconsin who built a new home this fall.  He specified geothermal and the contractors installed a 4.5 ton Econar FA heat pump with a horizontal ground loops.  The contrators instructed my friends to go down to the local Menard's and purchase several pallets of windshield washer fluid to use to fill the ground loops?  I've never heard of this.  Is there any know issues with using washer fluid as the system's antifreeze?  Everything seemed to be functioning OK when I was there (it was -10F).
04 Jan 2009 07:53 PM
I have heard of this practice.
Can't say if it is ok or not.
geo fanUser is Offline
04 Jan 2009 08:30 PM
I heard at a geo class put on by Carrier , that its exactly the same stuff , sold as washer fluid to make it seem more eco friendly
04 Jan 2009 09:18 PM
I'd be skeptical - the stuff is cheap, but formulation questionable - there may be alcohol, ammonia, who knows what else, and that may vary from batch to batch. I'd want a better handle on what's in it and its compatibility with geo plumbing.
For northern geo apps antifreeze is a vital quality, but also need conductivity and viscosity so as to maintain heat transfer and turbulent flow.
cnygeoUser is Offline
05 Jan 2009 11:51 AM
If you stick with the cheap blue stuff I believe it's only methanol, water, and dye (at least according to the MSDS). The concentration of methanol will probably vary slightly depending on brand, batch, etc, but if you use an accurate hydrometer to mix it to the desired concentration it should be the same as using straight methanol (and a lot safer).
05 Jan 2009 07:47 PM
MSDS - good catch.
waterpirateUser is Offline
08 Jan 2009 04:42 PM
Here methanol is readily available,  we simply do the math to 20%  add it directly to purge cart, pop in a rit dye tab or two, add water and swirl.  When the pretty colors come back to the purge cart we continue for a time then check the mix with a hydrometer.
Eric
I like it!
People Online People Online: Visitors Visitors: 214 Members Members: 0 Total Total: 214
