Posted By conniepangan on 01/16/2009 2:14 PM
Tech, I talked to my installer about this and he's not recommending me to turn off the auxilliary heat. Does your bill improves without the back up?
He's right, the system could explode. Make sure your 10 miles outside the blast zone for safety.... NOT! Turning it off isn't going to hurt the system one way of the other and if you getting a 1 to 1 ratio compared to a 3 to 1 ratio your saving $... I don't have figures to back up my claims, but logically you can see your saving $.
quote = "Geodean"
Every house is different when it comes to the balance point of needing aux heat.
As Geodean says, there a temperature point where AUX heat is required reguardless how big your system is. If it got cold enough outside, even my house would require AUX heat to keep it warm, because the heat loss would exceed the Geothermal system ability to keep up with the load. Now determining what the exact point is the tricky part, but if it happens rarely, why would you want to waste $ when you don't need to?
I say try it, if it doesn't offer any benifits you can certainly turn it back on. The worst that that could happen is in a closed loop system it could draw the heat out of the ground faster than it could recover, there by giving you issues in the future. If that happens, you can turn the aux heat back on, it will use more AUX heat than normal until the loop recovers.
I'm at the point I'll try anything to make my bills lower, hell I'm thinking of sacrificing small animals to the heat gods to see if that helps.....
