Pick up/order a Wattnode
KW is a thousand watts
KWH would likely interest you more , these measurments must be taken over time (H is for hour)
If you want to know Voltage times Amperage divided by 1000 and correct for Power factor ( estimate .80 will vary ) estimate run time , and estimate LRA on system KWH and you get a very estimated answer
In short pick up a Wattnode
