Posted By shaedog on 01/29/2009 4:10 PM
my concern is that looking at the charts the load side presures are quite small.....meaning accuracy?
fun...this is....
the numbers on the chart are the pressure drop across the coil, not the actual pressure you will be reading. So you are looking for a difference in pressure of 1.1 pounds from In and Out.
Maybe you understand this, yes you will need an accurate gauge to show a 1.1 psi delta.
