What, exactly, is a 'flow center'
Last Post 24 Feb 2009 12:14 AM by tuffluckdriller. 4 Replies.
TomWSUser is Offline
23 Feb 2009 10:01 PM
I've seen this term used throughout this forum and elsewhere in GT discussions and have not yet determined what distinguishes a 'flow center' from a circulator pump.
I have seen references to items that, in addition to pumping, have a configuration that simplifies purging and are non-pressurized, but it's unclear to me if these are really distinguishing characteristics as I've seen things called 'Flow Centers' without these characteristics.
Tom
23 Feb 2009 11:08 PM
Flow center provides mounting point for circ pump(s), isolation valves
23 Feb 2009 11:13 PM
http://www.flowcenterproducts.com/
Bill NeukranzUser is Offline
23 Feb 2009 11:17 PM
And they're not a required item for a water loop.  For example, I don't have one.  You need purge ports, and you need pumps (for a water loop system), but you don't have to have them all together as one unit.  You can go 'a la cart.'
Flow Center: a term not needed for a simpler DX system.
People Online People Online: Visitors Visitors: 237 Members Members: 0 Total Total: 237
