IGSHPA defined Loop Spacing
Last Post 05 Mar 2009 06:09 AM by joe.ami. 23 Replies.
Bill NeukranzUser is Offline
02 Mar 2009 11:00 AM
Posted By geodean on 03/02/2009 7:45 AM
... If the conductivity is changed to .5   ( dry sand or clay ) then the  data looks like this
On a cooling dominated building with
 Bore Hole Spacing             Bore  Length Needed            Delta T of ground after 25 years
25'                                        1614'                                                 +1°
20'                                        1660'                                                 +1.8°
15'                                       1764'                                                 +3.3°
10'                                       2060 '                                                +6.8°
I'd like to check in here to affirm that I understand what this is saying (noting the correction too that this is for a 4 ton system):
I have clay soil, I'm in a cooling dominated climate (not building though), have an 8 ton bore hole field (2400' bore length total), and my holes are spaced about 20' apart.  Does this indeed say:
* I'll probably experience some amount of ground Delta T heating over the years?
* In my case, noting the bore length I have and the 20' spacing I have, my ground Delta T heating over the years will be negligible?
Many thanks!
02 Mar 2009 11:18 AM
Bill,
I doubt that your clay soil is dry. So assuming that your soil is at least damp, I think you can rest assured that your Ground Delta will be negligible.
02 Mar 2009 12:10 PM
Posted By geodean on 03/02/2009 11:18 AM
... I doubt that your clay soil is dry. So assuming that your soil is at least damp, I think you can rest assured that your Ground Delta will be negligible.
Dewayne, thanks.  I agree - I'm probably higher up on your soil characteristics chart.
It's interesting to see that all clay compositions are in some kind of 'rare' category.  I didn't realize my Texas clay soil wasn't as common as I thought.
To stay out of a 'rare' or 'extremely rare' category, my guess is I have Damp Silt/Clay or Saturated Silt/Clay.  And based on the amount of water that came out when my holes were drilled I'll guess I have Saturated Silt/Clay.
This is an interesting subject.
Many non-geo HVAC contractors in my area include this 'fact' (heats up the soil, grass won't grow so well, etc.) to pursuade potential customers to install conventional or air-to-air heat pump equipment.
I think I'll contemplate how I could use my WEL instrumentation system data to eventually prove with fact that indeed there's no ground heating effect.  While I don't have a ground temp probe, my guess is EWT shown in some manner would suffice (i.e., rolling 12 month average EWT over a 10 year period - 108 data points).
Thanks!
If heat keeps grass from growing, how come you still have to edge an asphalt driveway? Don't they get a little warm in the sun?
People Online People Online: Visitors Visitors: 313 Members Members: 0 Total Total: 313
