Water furnace Envision series questions
Last Post 12 Mar 2009 08:59 PM by joe.ami. 2 Replies.
Jesse097User is Offline
12 Mar 2009 08:27 PM
Hello,
I am a new to this forum, but I have been trying to find a website for some support, so I thought I would give this a try. I had installed a water furnace "evision series" 2 stage, I live in Wisconsin before I forget, it was installed just over a year ago, I built the house 5 years ago and had a propane furnace, so instead of getting rid of a fairly new propane furnace had the installer set it up for use as the back-up heat instead of buying the electric back-up that can be purchased with the water furnace, anyways to the problem, a few cold spells these past few months, made the propane furnace (back-up heat) kick in, it would run for the 10-15 minutes until it brought the temp and then the water furnace is called in to finish the call, this is the way the installer had programed the thermostat, the problem is propane furnace burner shuts off-water furnace pump and fan start-but propane furnace fan is still running until bonnet cools off.....both furnace fans running at the same time, causes alot of noise, also trips the air flow indicator light on the water furnace each time, installer advice get rid of propane furnace, install electric back-up, not the anwser I am looking for....any comments, solutions, anything would be great!
geo fanUser is Offline
12 Mar 2009 08:39 PM
install or increase the time delay on the geo
a added controll at a small cost that will keep the geo from coming on for a few minuets on a call for heat
most units come with a delay that possibly could just be adjusted
While it can be fixed, electic aux is cheaper than propane furnace most of the time. Listen to your contractor.
J
People Online People Online: Visitors Visitors: 215 Members Members: 0 Total Total: 215
