Superinsulated house with small GSHP
Last Post 11 Jun 2009 08:47 PM by engineer. 41 Replies.
Page 1 of 3123 > >>
Nick735User is Offline
26 Mar 2009 10:47 PM
I am currently in the design stages for my home, and am trying to figure out what I am going to go with for my heating system. I am attempting to build it up to superinsulation standards  (r40 walls, r60 roof) where in some homes a conventional heating system is not even required.  However, since its difficult to source extremely energy efficient windows and doors, and i dont want to be too limited on certain architectural features, I was thinking of going with a small efficient heat source.  Since I have my own heavy equipment and plenty of land to run a horizontal system, i was leaning towards using a small gshp (1 to 1.5 ton?). Does anyone know of anyone doing something similar, and do small gshp's even exist?   I have looked at other options - solar w/ radiant,  ashp's, but i was realy attracted to geothermal due to consistent ground temps, high efficiency, and the ability to heat dhw when coupled with a desuperheater.
27 Mar 2009 07:22 AM
Smallest mainstream manufacturer units are 2.5 ton in 2 stage and 2 ton in single stage.
There may be other options - I believe I've seen smaller units down to 1/2 ton but I don't believe they connect to ductwork
27 Mar 2009 07:40 AM
Climatemaster had a Genesis in 15 or 18KBTU (don't know current availability) and a Tranquility 20 18Kbtu. Don't think 2 stage is too interesting if load is truly this small.
To that point we are way ahead of ourselves, what is the manual J load for the home?
Odds are a heating system is required by code in your area so going without is not an option.
If the load is as small as you suggest, you will have to take a hard look at op cost calcs before going geo.
Incidentally, this comes up from time to time. If you are able to do your own excavation, the most it will save you around mid MI is about $400/ton. It is often less than 10% of the job cost. Add in the lost tax credit and your price difference could easily slip under $1,000.
J
geo fanUser is Offline
27 Mar 2009 04:29 PM
Advanced Geothermal ( which is DX )
starts at 1.5
http://www.advgeo.com/proddes.html
bartman99User is Offline
28 Mar 2009 07:14 AM
Looks like Hydron Module goes down to 1.5 ton too.
28 Mar 2009 10:21 AM
EarthLinked lists a 1.5 ton. I'm guessing, though, that any manufacturer listing one doesn't necessarily have it in stock, and that it's a special order item.
28 Mar 2009 08:09 PM
Just curious as you haven't responded nick, what is the manual J load calc for the home?
j
29 Mar 2009 07:59 PM
Sorry I am so slow replying to my own thread, but I was away this weekend and didnt have time to post. No i havent done a manual J load calc on the house. I know its probably always better to have a professional calculate it, but do you know of any free online sources that could give me a rough ballpark?
Here are a few specs on the home and let me know if you think it is far fetched to go with such a small system.
1800 sqft cape
Windows- Triple pain with U values of .2
Walls- 8.5" SIP walls w/ 1" XPS sheeting to eliminate thermal bridges
Roof- 4" closed cell spray Foam, 8" Cellulose, 1" XPS rigid foam to eliminate thermal bridges
31 Mar 2009 02:56 PM
Where (what city) is this house?
egouinUser is Offline
31 Mar 2009 06:31 PM
Nick,
I just completed a superinsulated house. We have a GSHP (two actually). One thing I did not consider prior to the commissioning of the house... the de-superheater is going to give you VERY little hot water because the system will not be running very much. I am currently investigating solar hot water. Feel free to contact me with questions.
Regards,
Ed
http://www.GouinGreen.com<br>Superinsulated SIP/Modular House (HERS = 30)<br>GSHP w/SCW, ERV, Passive Solar, Solar HW
31 Mar 2009 08:21 PM
Jeez i forgot to mention one of the most important things about the house; its location! It will be located in northeastern CT... since CT is so small i doubt you'll need the exact city ;-).
Ed- Yea i was thinking that a desuperheater may not provide enough heat, especially if i am going with a small system. I am currently finishing a home right now that has solar heating via radiant. We havent fired it up yet, so i cant report how well it works, but I was considering going with a similar system for my dhw. Radiantec has a a package that consists of 2 solar panels, water tank, and all pre made manifolds for just under $4k. I dont want to go with solar & radiant for my personal home because unless you go with a slab, the cost and efficiency of the system goes out the window.
What are the specs on your house? Sqft, Insulation, windows & doors, size of heating system etc? It would be great to bounce ideas off of each other.
Nick
31 Mar 2009 08:41 PM
hello neighbor
I would push for a desuperheater , on the sole fact that it is required to be eligible for the 30% tax break .
I would say a PV system and electric hot water as the main source of hot water would give the best bang for porky buck
PV is CT is close to 75% paid for through state and fed credits
RsipgeoUser is Offline
01 Apr 2009 06:41 AM
The most expensive part of geo is the looping so maybe it's not a bad idea, though on the other hand they say that those "passive" houses can be heated with the equivalent of a hair dryer so maybe anything is overkill.
Do a manual J. Versatec by waterfurnace has some smaller units.
01 Apr 2009 08:10 AM
I know of plenty of places you can get a man j done for $50 but not for free.
mkramerUser is Offline
01 Apr 2009 09:07 AM
Hey geo fan, a desuperheater is not, i repeat not required to get the 30% tax credit!  In order to qualify you units must meet Energy Star rating.
01 Apr 2009 09:12 AM
Egouin, what kind of heat pump did you put in, the very little hot water should not be true.  When the unit is in cooling, you should get 100% of your hot water, when in heating, you should be getting about 80% of your hot water, something does not sound right to me here, give me some more info, by the way, did you do this yourself or hire someone in the industry?
01 Apr 2009 09:57 AM
Mkramer,
My understanding (and I've seen the language in the bill) is the DSH is required, I can't point you to it at this time, perhaps one of our other friends can.
Also a DSH only offers about 10% of unit capacity for hot water so a 1.5 ton for instance only provides 1,800 btu for hot water (when the unit is running). Even in july, you won't be filling the hot tub with that kind of production. Further as Egouin points out you only get the 1,800 btu when the thing is running.
J
01 Apr 2009 10:46 AM
Hate to correct you joe.ami but here is the link for the desuperheaters we use
http://www.fhp-mfg.com/newpdfs/HRP.pdf
maybe you need to buy a better desuperheater!
01 Apr 2009 10:57 AM
Also, go to the white house website, search for desuperheater in H.R. 1, it does not exist in 455 pages of legislation!
There is NO reqmt for a desuperheater, please stop putting out false information, you are hurting our industry.
cnygeoUser is Offline
01 Apr 2009 11:15 AM
Posted By mkramer on 04/01/2009 10:57 AM
Try again - the heat pump needs to meet Energy Star Criteria to qualify, which includes:
"In addition, some or all of the domestic water heating shall be provided through the use of a desuperheater, integrated demand water heater or a separately installed compressor that provides demand water heating."
http://www.energystar.gov/index.cfm?c=geo_heat.pr_crit_geo_heat_pumps
You're correct that it doesn't absolutely require a desuperheater, but it does need some form of water heating.
Hope it doesn't hurt the industry too much if one of your customers gets audited and penalized because they don't have any water heating capability!
Page 1 of 3123 > >>
People Online People Online: Visitors Visitors: 202 Members Members: 0 Total Total: 202
