Geothermal Heat Pumps
Looking for water temperature sensors ...
Last Post 10 Apr 2009 07:24 PM by
dancour
. 5 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
dancour
01 Apr 2009 07:26 AM
I would like to install simple, low cost, water temperature sensors, on my HP's incoming water and outgoing water lines.
Any suggestions and or pictures appreciated.
Brock
01 Apr 2009 08:24 AM
Do you mean ones that are stand alone? If so I just use the cheap indoor / outdoor thermometers with a 10 foot outdoor probe from our local home box store. I bought 8 of them and put sensors in water and matched them all up. I had one about a degree high and one about a degree low, but the other 6 were within .2F of each other. I put matching ones on the incoming and outgoing field lines, using electrical tape to attach the probe against the copper and then put the insulation back on. They have a min / max temp as well so I know the lowest temperature the incoming field temp is and record that every week.
For computer reporting, I don't know of anything cheap. The WEL would be my choice if I could scrape up the money.
joe.ami
03 Apr 2009 08:40 AM
Brock,
Do you have name and source of your thermometers.
J
Brock
04 Apr 2009 08:31 PM
I am using two different models, I got one at Home Depot and one from Menards (a mid west Home Depot type store). I have seen very similar ones on
ebay
, but I got mine on sale for $4.99
jongig
08 Apr 2009 01:38 PM
I used a two temperature 1 week data logger made by Taylor. It's about $41 at Grainger and has worked very well. It maintains a different high/low temperature for each of 7 days. I atached the probes to a bronze fitting on the in/out og my GSHP and have watched the temperatures all winter. It's accurate and addjustable under the cover.
http://www.grainger.com/Grainger/wwg/productIndex.shtml?L2=Two-Temperature&operator=prodIndexRefinementSearch&originalValue=temperature+logger&L1=Data+Loggers%2C
dancour
Well, I thought I'd try Brock's idea first. See attached pic.
I'll look into Jongig's suggestion next.
http://www.grainger.com/Grainger/wwg/productIndex.shtml?operator=prodIndexRefinementSearch&originalValue=temperature+logger&L1=Loggers%2C
Thanks guys!
Now to find an inline water flow meter.
Membership:
croccohvacusa
People Online:
