Ground Temperature Information
Last Post 27 May 2009 12:25 AM by dmaceld. 11 Replies.
EmmonsUser is Offline
26 Apr 2009 10:17 PM
Does anyone have a source for data on the ground temperature for a give location, lattitude, or other basis? I have an in-ground swimming pool. Can I measure the water temperature in the deep end and use that as a good indicator? I do not have a heater on the pool. Thanks in advance Tommy
heatoftheearthUser is Offline
27 Apr 2009 07:34 AM
http://smu.edu/geothermal/heatflow/surtemp.htm
BergyUser is Offline
27 Apr 2009 07:44 AM
The ground temp, below the frost line, for any area will always be within two degrees of the yearly average temp for that area.
Bergy
27 Apr 2009 08:35 AM
Two many variables on the deep end of the pool.
J
BrockUser is Offline
28 Apr 2009 01:59 PM
If you are running no circulation the temp at the deep end will be close to the ground temp assuming it is about 8 feet deep. But if you not running any circulation you likely have a swamp or pond and not a pool ;) The circulation pumps move the heat around pretty well.
hector8762User is Offline
29 Apr 2009 02:41 PM
Do you know what your average annual mean temperature (MAGT) is? (For Baltimore, MD it's about 57 deg F) Google on this if you don't know have it.
At a depth of 1/2 meter, the temperature varies 14 deg F. So, if your MAGT is 60 deg F, the ground will vary between 46 and 74 Deg F at a depth of 20 inches.
At 1 meter, temp varies 12 Deg F
At 2 meter, temp varies 7 Deg F
At 3 meter, temp varies 4 Deg F
You have to go down to almost 13 feet to get a temperature variation of two degrees fahrenheit
Obviously, this is just a guide.  Your mileage may vary.
Don't use your pool temp. Even without the pump, convection currents stir the water.
FarmboyUser is Offline
30 Apr 2009 10:32 PM
I get about 57°F  for the water from my 80 ft deep well.  From the NOAA website, the average Wichita, KS, air temps range from 54° to 59°.  So Bergy's theory that deep ground temps are within 2° of the average annual air temps seems to be valid for south-central Kansas assuming the water temps approximate the earth's.  Dave
gregjUser is Offline
01 May 2009 11:16 AM
The best answer is "it depends"
What do you mean by ground temperature? 1 inch down, 10 ft down, 1 mile down?
Bergy's statement on the yearly average temp is generally true in most areas but as Hector pointed out the depth of the ground affects the temp swings.
Hectors info on variation is probably correct in his area but is based on the temp swings he gets. The 2 meter ground temp swings in south Florida might be a lot less.
And if you are in an area with geothermal activity near the surface then the seasonal temp change may be irrelevant.
OnaUser is Offline
22 May 2009 01:44 PM
http://www.geochoices.com/soil_and_ground_conditions.html
TechGromitUser is Offline
22 May 2009 02:58 PM
Posted By gregj on 05/01/2009 11:16 AM
I wonder how far you have to go down before you start getting into heat from the liquid core of the earth?  With hot enough water you could by pass the geo system entirely. Would the electricity the pump uses be worth the effort? Can Tuffluckdriller or Douglas Walker give us drilling qoute per mile?  And if you drill too far, instant volcano?  This is kind of crap I wonder about.
26 May 2009 09:37 AM
Posted By TechGromit on 05/22/2009 2:58 PM
Sure TG, and how many cups of sugar does it take to get to the moon?;)
Posted By Emmons on 04/26/2009 10:17 PM
Contact the state agency that issues permits for drilling water wells. They should have available well driller reports for all water wells drilled in the state, and maybe even have them online. The reports quite likely will have the water temperature when the well was drilled. Look for reports for wells on the order of 50 to 100 feet deep close to you. That's probably as good information as you'll find anywhere. Reports from various times of the year will give you an idea how much the temperature varies seasonally. Won't be much, if any. And most likely will be in the range of 50-60°F.
People Online People Online: Visitors Visitors: 327 Members Members: 0 Total Total: 327
