Geothermal (vertical closed loop) and Steel casing
Last Post 27 Jun 2009 10:46 AM by samirshah. 8 Replies.
samirshahUser is Offline
01 Jun 2009 07:32 PM
Question: Does anyone have an illustration or explanation of where steel piping/casing is installed on a residential geothermal install? Is it toward the top (where the soft soil is) or toward the bottom of the bore (where it's rocky)?
01 Jun 2009 10:07 PM
Are you talking about open or closed loop?
I'm not a driller, but I'm not aware of a casing requirement.
J
01 Jun 2009 10:56 PM
I should have phrased my question a bit better. J, it is NOT a requirement, but where I am located -- Northern New Jersey -- we hit rock approximately 100 feet below the surface (100 feet is just an educated and experienced estimate, we are STILL going to drill a test hole to get a more solid quotation). BUT, I have found the answer to the question. It is in the attached DOC file.
01 Jun 2009 10:57 PM
Here is the URL for the DOC: www.aeeny.org/news/newsletters/2008/December_1_2008_Newsletter.doc
08 Jun 2009 10:42 AM
If you went with EarthLinked DX, 100' is plenty, and you don't need the expense of the test hole.
conniepanganUser is Offline
10 Jun 2009 02:36 PM
What part of North Jersey are you? I think we encountered the same at about 400' below. I am in Essex county.
12 Jun 2009 08:33 PM
I think the purpose of casing is to isolate 'good' deep aquifers from poorer quality surface / shallow aquifers
From what I've read casing requirement vary considerably by locality.
New Jersey probably prohibits most activities and heavily tolls or taxes the remainder...
hcp27golferUser is Offline
27 Jun 2009 09:19 AM
DX in New Jersey
Division of Water Supply
Bureau of Water Systems and Well Permitting
P.O. BOX 426
TRENTON, NEW JERSEY 08625‐0426
TELEPHONE (609) 984‐6831
FAX (609) 633‐1231
STATE WELL DRILLERS AND PUMP INSTALLERS
EXAMINING AND ADVISORY BOARD
State Well Drillers and Pump Installers Examining and Advisory Board
Meeting Minutes for January 27, 2009
He also proposed sending letters to local inspectors notifying them of the fact that DX systems have never been approved. H. Chudzik questioned whether the Board of Public Utilities had been approving and/or endorsing such illegal systems. A. Becker also questioned whether the Bureau could investigate systems that are believed to have been illegally installed within the state so they could also serve to yield data regarding the longevity of such systems.
For entire text see.
http://www.nj.gov/dep/watersupply/minutes_1_27_09.pdf
conniepangan: We are in Morris County -- not TOO far from where you are. Were you 'REQUIRED' to place AND KEEP steel casing in your bores? Please let me know. Thank you.
