Earthloop under footing
Last Post 17 Jun 2009 08:56 PM by engineer. 5 Replies.
BuntlyUser is Offline
15 Jun 2009 01:33 PM
I will be doing a 2000 sq foot ranch in about a month. It will be icf construciton from footing to eave. The home will have radiant heat in basement as well as first floor. The home will have geothermal as well. The footing will be about 8 to 9' below grade. In the past I have run the earthloop thru the wall above the footing. Do any of you pros see an issue with running the earthloop below the footing? Thanks in advance!
Bunt
Bunt
15 Jun 2009 04:29 PM
We run under footings sometimes. You need to allow for the loop freezing the dirt around the pipe so as not to heave your footing. Bed in gravel so as to avoid heaving.
16 Jun 2009 08:00 AM
Sure don't get so many oppurtunities for leaks that way.
J
16 Jun 2009 09:28 AM
Thanks Dean,......that's what I was thinking.  We would like to do all the excavation in one shot. Going under the footing would work best for us. I also like the ideal of simplifying the waterproofing as well.
Thanks again!
Bunt
Bunt
BergyUser is Offline
16 Jun 2009 01:02 PM
Buntly,
In new construction we always go under the footings. We insulate the pipes all the way under the slab and several feet outside the foundation.
Bergy
Sprayfoam the roof and that house might be able to be heated with a candle or two.
Does pipe insulation suffice to keep adjacent dirt from freezing? I'd guess the effect would be lessened but not eliminated entirely.
Gravel bed sounds like good insurance.
People Online People Online: Visitors Visitors: 153 Members Members: 0 Total Total: 153
