Geothermal Heat/Cool with SIPS Built House
Last Post 08 Jul 2011 10:24 PM by BadAttitude. 23 Replies.
25 Jun 2011 10:37 AM
As a side note regarding efficiency, the figures I've seen indicate that one can beat the efficiency of a radiant concrete slab with tile over aluminum panels. You also get faster response time and less overshoot.
docjenserUser is Offline
25 Jun 2011 04:07 PM
Posted By jonr on 25 Jun 2011 10:37 AM
Absolutely. It comes down to how much extra you are willing to pay for a certain amount of additional efficiency. I was describing a building where you put the pipes in the concrete, and the only difference is a bit more plastic pipe and a bit more labor effort to put it at 8" OC. To put another subfloor with aluminum on top of the concrete would have been cost prohibitive.
25 Jun 2011 04:29 PM
I agree - it's more appropriate for an upper floor.
BadAttitudeUser is Offline
We built an SIP sided timberframe home (5000 sq ft) in 1999 with a 4 ton geothermal loop system and couldn't be happier with both technologies. Conventional HVAC people calculated that here in East Tennessee that we would need 12 tons of cooling/heating, but we rearely get into the second stage of cooling. The only thing I would warn against is using SIP panels for the roof unless they are supported every 4 or 5 feet by interior beams. Also make sure that the roof is vented.
Carl
People Online People Online: Visitors Visitors: 377 Members Members: 0 Total Total: 377
