Horizontal loop pipe size
Last Post 09 Aug 2009 12:22 PM by Alex_in_FL. 25 Replies.
02 Aug 2009 05:57 PM
Posted By engineer on 08/01/2009 8:40 PM
I don't think 84 deg soil will yield 89 deg EWT for long unless the field is very large.
I would agree.
03 Aug 2009 07:21 AM
Posted By geodean on 08/02/2009 5:57 PM
I don't think 84 deg soil will yield 89 deg EWT for long unless the field is very large.[/quote]
I would agree.
That's the whole point isn't it? Because an ASHP or central AC are already heat pumps, a watersource system trying to cool on very high EWT's could cost as much or more to run. Worse yet as some can attest to, it may lock out on the hottest days.
You can mitigate some of the trouble with large loop fields, but there is a practical limit. Dry sand (slow heat migration), high ambients, high demand at some point become a "3 strikes your out situ." Some areas may require vertical systems only.
joe
cajundrillerUser is Offline
03 Aug 2009 09:28 PM
Pex/Al/Pex drilled closed loop into a radius with outer radius @ 45 deg and middle radius drilled @ 30 deg and inner radius drilled @ 15 deg would be most optimal at say 100' per 4"borehole. CLOSED LOOP GEO-THERMAL CLUSTER.In process of doing the first one now at 9879' elevation INDIAN MOUNTIAN , COLORADO.Topmanifold area fits in a 10' radius w/ a 20' diameter.Further enhance this conductivity as you call it by using a thermal enhancing super grout.Also if at all possible drill this cluster first right under basement slab.I have patented this idea Jan 1,2009.It will and is going to work come hell or high water.Now the Germans say they case thier boreholes w/ black coregated plastic pipe before they send loop and tremie downhole to further enhance.I don't know about it because in order for the colour black to conduct it seems it must be exposed to direct sunlight.I could be wrong and this is only my opinion.William Wainwright/Advanced Geo-Thermal Drilling LLC./Owner Operator
William Wainwright
1923mackUser is Offline
03 Aug 2009 09:38 PM
Another pipe in the bore hole besides the one carrying the fluid would seem to be counter productive.
04 Aug 2009 09:44 AM
Mack - That is what I am thinking - I am presently moving foward without it and leaving borehole uncased.
William Wainwright
Alex_in_FLUser is Offline
Soil temp is generally related to the average daily air temp of about a month prior. It varies less as you go deeper.
People Online People Online: Visitors Visitors: 290 Members Members: 0 Total Total: 290
