Posted By How on 07/24/2009 12:05 AM
VisionPro IAQ 9000 Honeywell programmable thermostat with outside temperature; controls temperature, humidity, and fresh air. It has a spot where you can lock out the auxiliary heater if it is above an outside air temperature; 0 degrees - 65 degrees, 5 degree increments. We use them!
....and it is fair to say that once you are below your balance point (temperature at which aux. may come on), you will then not save money by dialing back at night.
Good luck,
Joe
