Posted By bernman on 08/18/2009 7:20 PM
My wife and I are looking into building a 1950 sqft ranch in Connecticut with geothermal heating and cooling. We have 2 quotes so far for similar but different systems. They are both quoting a 3.5 ton closed loop system with a desuperheater. One is a Climate Master and the other is a Florida system. One is recomending 1-525' well and the other is requiring 2-300' wells. Which is better way to go?
Another question we have is that one has an electric hot water heater with a 10kw electric backup and the other a gas fired hot water heater AO Smith) with gas backup. Which system would be better and more effecient for pre-heating the hot water?
We are meeting with both contractors again within the next week and we wanted to get more info and opinions before speaking with them. I have learned alot from reading the posts on this forum but still have alot to learn. Thanks in advance for any input and suggestions.
Bernie
Bernie,
I've not heard of doing a single DEEP well before. Our systems use one loop per ton of required heating/cooling.
The desuperheater will not work with a single gas fired water heater. Two tanks, piped in series, allow the desuperheater to heat the water more efficiently. The first tank is the "buffer tank" and needs to be an electric water heater. The tank does not need to be powered, it's job is to allow the desuperheater to heat the water whenever the Geo runs. The second tank is for the final output to the home. It can be electric, or gas. A gas fired unit heat the water cheaper than an electric unit, however, some electric companies will not allow a gas heater if they provide rebates on your system.
The drawing shows how to pipe the two tanks together.
Bergy
