Geothermal Pond Based System In Tidal Creek
Last Post 01 Oct 2009 09:36 AM by jonr. 7 Replies.
Scott HarbinsonUser is Offline
23 Sep 2009 10:27 AM
Hi. I'm wondering if anyone has an opinion of using a tidal creek as the heat source for a geothermal heat pump. Many thanks!
23 Sep 2009 08:56 PM
No reason it couldn't be made to work. Tidal means excellent water movement twice a day - great for heat transfer. Tides also imply depth changes, salt water corrosion and bio-fouling issues. Design and install will need to accommodate those factors.
Freshwater biofouling consists mostly of algae and slime, not a big deal. Salt water biofouling involves thick encrustations of barnacles and shellfish...maybe you could farm raise mussels on the system's tubes, but you'd better make sure the heat will transfer through the fouling.
23 Sep 2009 09:07 PM
Excellent points, thank you. The issue of shellfish infestation is one I hadn't considered, and definitely a problem. I'll look into the difficulty of laying tubing below the subaqueous bottom and whether that would prevent the sort of problem you describe.
23 Sep 2009 10:37 PM
I would look at using copper or copper alloy pipes for a closed loop heat exchanger.  Also a water storage tank if the creek flow is insufficient at low tide.
24 Sep 2009 06:44 AM
Check into Slim Jim heat exchangers - those folks have probably dealt with this issue before - don't reinvent the wheel
24 Sep 2009 11:10 PM
Depth matters particularly in heating dominated climate as does body of government responsible for the water.
State DNR (or equiv.) may permit loops where Corps of Engineers may not.
Good luck,
Joe
Alex_in_FLUser is Offline
30 Sep 2009 09:20 PM
Jonr - are you refering to the internal coil or are you saying put copper pipes in the tidal pool?
Copper and alloys have the advantage of resisting fouling (in the tidal pool), but I said "look at" because there could be other issues. The Slim Jim (titanium or aluminum) suggestion sounds like the best advice.
People Online People Online: Visitors Visitors: 241 Members Members: 0 Total Total: 241
