Ok some new info-
I just recently bought this place (forclosure) and was figuring out the well and all the goodies in the basement. There is a second line coming in that I have determined that comes from the artesian well and was used to run a geo A/C unit. It has a little gorman rupp 1/20 hp pump that is burned up. I removed the pump and opened the ball valve and i have a pretty good artesian flow. I will have to measure the open flow but I think I can get more with a larger pipe as they necked it down almost half after it comes into the basement. The artesian well is between the house and pond and it tees off to both the house and pond, so shutting it off at the house is no problem. When I let it flow into the house it barely slows the flow to the pond. So if I use a pump I can get more to the house if need be.
So now new plan is to make a heat exchanger in the basement and control system.
Any Ideas on where to get info to do this?
I am thinking a 100' loop of copper in a 55 gallon plastic barrel with the artesian well water flowing through it and dump it back into the pond.
It it a problem if there is too much flow of well water through the homemade heat exchanger??
Also, how should I plum the copper coil in the barrel? Liquid side going into the bottom of the barrel and vapor out the top or vise-versa? How and where along the path do I make the transition between 1/2 copper and 3/4 copper?
