Posted By Alex_in_FL on 11/02/2009 3:58 PM
Just typing my thoughts:
What concerns me is that the trenches are only 1.5 feet apart. This means the middle trench has only vertical heat sinks and the other two only have three sided heat sinks.
So, my guess is that the loop is insufficient due to crowding the loops too close together.
If not familiar, 2, 4 and 6 pipe trenches all have pipes fairly close together but trenches farther apart. not sure if OP is describing a 6 pipe as Tek mentioned with back 2' of back-fill and return pass or a true 3 pipe which would out perform a 6 pipe trench by returning via another route.
j
