Posted By sx700r on 11/02/2009 11:43 AM
What is the most important reason for knowing EWT ...
One benefit of knowing your EWT, and tracking it over time, is to be able to assess the 'health' of your water loop, particularly if it's closed.
I.e., you can look up what your 'down deep undisturbed' earth temperature is, for your geographic location. And then watch EWT to see how much the swing is above and below the baseline earth temperature.
For example, my baseline earth temperature is 68° (F) (Dallas climate). And from the chart I started buuilding for EWT, shown below, I now know my EWT summer high was 83°, and winter low was 63°. This is a 'swing' of 20°, and it tells me 2 significant things: (1) my loop is performing quite well, and (2) my loop is probably oversized for my needs and thus I probably spent more money than I needed to.
As another example, if my chart were to show an 80° swing, with a projected high of 113° and a projected low of 33°, I'd know to be worried that my loop was either 'short looped' or broken in some fashing (i.e. no grout and no earth/water in contact with the pipe). (And that antifreeze may be needed!)
Another benefit of knowing EWT, this one even longer term, is to assess if you have long term heating of the earth. After I get some multi-year data, I'll easily be able to see if my earth is gradually heating up.
Hope this helps.
