I have a heat Controller Inc GeoMax 2 3 Ton heat pump that won't turn on the second stage of the compressor. The heat pump does not have electric backup heat yet. I have a Hunter touchscreen programmable thermostat model 44860.
The interface board of the heat pump is as follows:
Y2 Y1 G O W NC CI R DH AL1 A I have it connected to the thermostat as follows
Y2 Y1 G O C RC/R L
The thermostat also has W2(aux), E(Emergency), B(Reversing valve Heat), And W1(Heat stage 1 which they say is for conventional HVAC).
Stage one works fine. I have also switched from heat to cool and that Also worked. Does anyone have any Ideas.
