(Moderator - please move if in wrong section, but I couldn't find the best section. Thanks.)
I've been reading up more on duct work because of recent issues in return & supply ducts from the previous owners/installers. (See some of my other posts). The existing duct work was mated to a new geothermal air handler, currently set at 1100 cfm max blower speed.
House is 2100 sq feet of conditioned space, 2 floors, 2 zones.
My new HVAC guy wasn't going to redo all my ducts from the old central a/c, and basically, now, they do work, but I'd like to try and optimize them myself. I've read a lot about duct work and plenums and cfm per room per floor, return sizing, etc. I even have a copy of ACCA Manual D Residential Duct Systems, and it's certainly informative.
My current questions concern both supply and return.
Suppy - the air handler is in the basement, the main trunk runs horizontally across the basement, with the handler in the middle. A third line runs 90 degrees perpendicular and then into a vertical stack to the upstairs. Upstairs is about 900 sq feet, downstairs is 1200 sq feet.
The air handler blows straight up into the trunk through a T.
Illustration. Manual D indicates that the resistance created by such a configuration is far more than if it was more elbowed, possibly with turning vanes. Question: both work, but is the turning vane/elbow much better? None of my runs are more than about 40 feet total, from return vent to furthest supply vent. And what would be the best way to connect the vertical stack for upstairs? Currently, the horizontal ducts that supplies the stack is only 11x11, which seems narrow for up to 1200 cfm with Z2 on and Z1 off.
Return - obviously, the return should equal or slightly exceed the supply, so my goal would be to get 1100-1200 cfm back to the unit. I have 4 return vents, all near the center of the house, each measures 4x10, runs using floor joists as duct space for a few feet, then connects to a large return trunk of duct board. My initial calculations/observations suggest this isn't enough without the 4x10s having excessive velocity.
I"m hesitant to ask my geothermal HVAC guy for many reasons, notably I've already paid him a whole bunch of money, and I'm fairly handy as far as tweaking a system. I'm not looking to reconfigure the whole duct layout (I'd probably find someone with more experience for that), but tweaking it, adding an extra return, trying to streamline some of the duct work, I'm pretty sure I can do on my own.
