Posted By denwayne on 01/20/2010 11:26 PM
Just ran across this post. I've been trying to find info on an air + small geo sync system called "dual source heat pump" that seemed promising, but may have gone the way of the dino. Best I can figure, it put a water heat exchanger on each side of the air exchange condenser coils linked to a pump to run only when the compressor is on. Would this not pre and post cool refrigerant in summer(warming in winter), reducing pressures and load on the system, therefore making a more efficient (especially at the temp extremes) system? What happened to the original description of this guy's system? What is "Kilroy was here"? Is there anything like this out there? Old info indicates a loop of 30-60 ft /ton would be adequate when coupled w/air assist (one well instead of 4 for a 4 ton geo unit).
Thanks for any insight or info.
Original poster deleted his blogs. He apparently found law and honesty both too confining in the discussion.
You'll find some of his content in my posts.
I've not heard of the type of system you mention but it sounds like it could have some merit. Keep us posted.
J
