heat and A/C
Last Post 28 Jan 2010 07:50 AM by EDWARD. 2 Replies.
EDWARDUser is Offline
27 Jan 2010 03:14 PM
If you have a geo  heat pmp, I assume you can use it for both radiant heat as well as forced air  A/C. Do you have two exchangers , one for heat another for A/C ? Of course you will need ducts for the A/C and tubing for radiant heat , how does that work?
Edward
27 Jan 2010 05:08 PM
Unit may have both an aircoil for AC and a watercoil for radiant. It won't do both at the same time
Waterfurnace has a line called Synergy - check it out.
Thanks  I'll check it out.
Edward
People Online People Online: Visitors Visitors: 312 Members Members: 0 Total Total: 312
