hi first post, great site! i built a icf house in 2008 and put a geocomfort system in, i dont know if it is working the way it should? i dont even use the infloor it cant keep up. TIA 4 ton single pond loop 2000' of pipe at 200' from house, pond is 18' deep, 2/3 acre water to water W/desuper infloor basement, & shower air handler in garage set at 50 only runs at night 2800 sqft first floor, 2200 basement, 800 garage
im wondering how these temps seem to you guys loop in 32 F out 26 last winter it was at 34 in and 22 out, pond was only 7 ft deep then, now filled all the way up to 18' and loop is colder ?
storage tank set at 115 w/infloor its go's down to 80-84 and dont ever shut off, tried for 54 hours to warm basement up to 72, didnt happen, cant catch up forced air down to 94-98, it takes 45min to warm the house up 1 degree
another thing to add and seems odd to me is when they filled the loop up it still floated they had to tie bricks to it and now they had to put a check valve in because when the forced air is on it would send the return water through the return lines on my infloor? i dont know what is right or wrong, not many people to ask around here, besides the installers thanks again
