need help withmy geothermal furnace
Last Post 01 Feb 2010 10:36 PM by [email protected]. 5 Replies.
lrs118User is Offline
31 Jan 2010 05:16 PM
I have a 5 ton cold flow furnace with 8 loops at 600 feet each loop. My coil keeps freezing up. Can anyone help me?
31 Jan 2010 06:49 PM
What's a "cold flow furnace"? Which coil freezes up?
31 Jan 2010 09:04 PM
coldflow is made in miami fl and its the coil that the flow center is connected into and out thanks
31 Jan 2010 09:21 PM
Prior to freezeup, what are your entering and leaving water temperatures?
Is this an open or closed loop system? If closed, does it have antifreeze?
ACES-EnergyUser is Offline
01 Feb 2010 09:49 AM
Much more information is required. Water and air temperature are a good start, but detailed information regarding the installation, performance since installation, previous maintenance, pressures, flow, amp draw..etc.
IGSHPA Accredited Geothermal Installer
Alternative Carbon Energy Systems, Inc.  (A.C.E.S)
www.ACES-Energy.com
Servicing Upstate New York
Rochester, Buffalo, Syracuse
www.ACES-Energy.com
geodonUser is Offline
are you in cooling mode or heating mode when this happens? do you mean the air coil, the one the air is moving through or the exchanger which what the pump is connected to?
People Online People Online: Visitors Visitors: 168 Members Members: 0 Total Total: 168
