Federal Tax Credit
Last Post 03 Feb 2010 09:46 AM by heimdm. 3 Replies.
stevedibUser is Offline
02 Feb 2010 10:08 PM
Has anyone encountered this guidance on the tax credit?  Until reading this it was my understanding that the tax credit was taken on the entire cost of the system including ground heat exchanger, equipment, piping, ductwork, controls, etc.
http://tinyurl.com/geotaxcredit
<!--[if gte mso 9]> Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4 <!-- /* Font Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:1; mso-generic-font-family:roman; mso-font-format:other; mso-font-pitch:variable; mso-font-signature:0 0 0 0 0 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1610611985 1073750139 0 0 159 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman","serif"; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; font-size:10.0pt; mso-ansi-font-size:10.0pt; mso-bidi-font-size:10.0pt;} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.0in 1.0in 1.0in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> <!--[if gte mso 10]> The majority of the geothermal heat pump property and it's installation is covered by the 30% tax credit. All geothermal heat pump components certified by the manufacturer in the "Manufacturer Certification Statement" will be covered. There may be some add on components that will not be covered such as an emergency back up system and the ducts. These components are not directly related to the efficiency of the covered geothermal heat pump property.
IRS Guidance: Notice 2009-41 Section 3. (1)(e) Qualified geothermal heat pump property expenditures are expenditures for equipment which uses the ground or ground water as a thermal energy source to heat the dwelling unit or as a thermal energy sink to cool the dwelling unit, meets the requirements of the Energy Star program which are in effect at the time that the expenditure for such equipment is actually made (even if under § 25D(e)(8) the expenditure is deemed made at a later time for purposes of determining the taxable year for which a taxpayer may claim the credit), and is installed on or in connection with a qualifying dwelling unit.
gregjUser is Offline
03 Feb 2010 08:48 AM
This is one persons interpretation. So what qualifications does this person have? What precedents is he using to develop his interpretation? I would throw that interpretation in the trash unless he has some rulings to back it up. The IRS Guidance you posted doesn't say that. What it says is very vague - probably purposely.
The ugly truth on tax laws is that we really don't know what is "legal" and therefore "correct" until it has been litigated a few times due to either taxpayers or IRS agents having their interpretation challenged in court.
I figure if you have your contractor give you a bill for the geo system then everything on that bill is covered because it is all part of the geo equipment and the geo won't work right without it. Probably a good reason for contractors to not break out costs though.
G.O. JoeUser is Offline
03 Feb 2010 08:54 AM
The is no definitive guidance out on this yet (I am sure there will be when the IRS finds out what people will be claiming).
The only help for now maybe the Energy Star Specification here-
http://www.energystar.gov/ia/partners/prod_development/revisions/downloads/geothermal_heat_pumps/ES_V3.0_Geothermal_Heat_Pump_Specification.pdf
Energy Star defines a GHP as-
A. Geothermal Heat Pump: A geothermal heat pump uses the thermal energy of the ground or groundwater to provide residential space conditioning and/or domestic water heating. A geothermal heat pump model normally consists of one or more factory-made assemblies that include indoor conditioning and/or domestic water heat exchanger(s), compressors, and a ground-side heat exchanger. A geothermal heat pump model may provide space heating, space cooling, domestic water heating, or a combination of these functions and may also include the functions of liquid circulation, thermal storage, air circulation, air cleaning, dehumidifying or humidifying. A geothermal heat pump system generally consists of one or more geothermal heat pump models, the ground heat exchanger(s), the air and/or hydronic space conditioning distribution system(s), temperature controls, and thermal storage tanks.
Consult your professional tax advisor.
heimdmUser is Offline
One way you could also read it as... the less detail that is on the invoice the better off you are... If you invoice read installation of 1 geothermal system.. that would be better than x for geo, y for installation, and z for duct-work.
People Online People Online: Visitors Visitors: 201 Members Members: 0 Total Total: 201
