Geothermal Heat Pumps
Loop Software
Last Post 04 Feb 2010 09:55 PM by
engineer
. 2 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Ozark01
04 Feb 2010 08:59 PM
What loop design software do you guys use? I seem to get a wide variation in the pipe required. For example for a 3.5 ton system if I use a single 1" pipe the trench would have to be 1680' long for a total of 1680' of pipe. If I use a verticle slinky setup the trench would need to be 690' long with a 1000' of pipe every 125' of trench for a total of 5440 feet of 1" pipe. Does anyone know why the difference would be so great in the amount of pipe needed?
Palace Geothermal
04 Feb 2010 09:45 PM
Slinkies use less ground mass and require more pipe to keep the same EWT.
engineer
Each turn of a slinky coil is close enough to the last and the next so that they impact each other's bit of dirt
Membership:
croccohvacusa
People Online:
