Driller Question
Last Post 08 Feb 2010 11:07 PM by engineer. 4 Replies.
pensiboyUser is Offline
05 Feb 2010 07:15 PM
In a vertical closed loop system will there be a PVC pipe out of the ground like you see with a regular water well?
thank you in advance
waterpirateUser is Offline
05 Feb 2010 07:19 PM
No.
docjenserUser is Offline
08 Feb 2010 08:30 PM
Hopefully not only heat fused PE pipe should be used. In europe they have used PVC in the past, but PE is much better, longer lasting, more durable
arkie6User is Offline
08 Feb 2010 10:23 PM
I'm thinking he was referring to the well casing, not the actual heat transfer loop material.
Answer remains "no"
People Online People Online: Visitors Visitors: 158 Members Members: 0 Total Total: 158
