GEO radiant woes
Last Post 22 Feb 2010 10:17 AM by geotek. 1 Replies.
geotekUser is Offline
22 Feb 2010 10:09 AM
The issue with limited information.
The house is new ICF construction, 5T water to water Geo unit, have a 50 gallon buffer tank, lower level floor is concrete, main floor is gypcrete. System was designed for the house or so I was told. There is NO outdoor reset. Floor tubing is in the gypcrete and concrete 12" on center.
On cloudy days, the house stays comfortable, just on sunny days when the geo does not run all day is when there are comfort issues. The house temp stays above the set points on the thermostats and the water in the system cools to about 82 degrees. The normal set points on the system points are geo on at 92 and off at 98. So when the whole system is calling for heat and the water temp is 82 the geo runs all night before normal temps are regained.
So, slow to heat thermal mass with slow to heat water gives me uncomfortable house on cold evenings after a sunny day.
I see a couple of problems here but thought I'd run it by the pro's.
Scrub that I placed in wrong forum.
People Online People Online: Visitors Visitors: 221 Members Members: 0 Total Total: 221
