Problem with your heat pump? Start here.......
Last Post 23 Dec 2021 06:07 AM by Mack56M. 27 Replies.
ICFHybridUser is Offline
23 Feb 2014 10:33 PM
Carl Odle, Homeowner with common GEO problem??
OMG. "Start Here..." means read this FIRST and then start a new thread.....
cgmcleodUser is Offline
25 Feb 2021 06:34 AM
I am having a problem with my Geothermal Heat Pump 4 Ton?? it is making a clunking sound.
25 Feb 2021 06:36 AM
I have a 4 ton Heat Pump Geosmart, I am having a problem noise. the noise begins when the Heat is beginning into the force air system then I hear a clunk at the end. Over time this clunk has become louder. what is it and what should I do about it.
Robert VearUser is Offline
23 Mar 2021 02:15 PM
Iron mud in well pipes.
Is there a process to clean the iron mud out of the pipes of an open loop well system?
I clean the coils 2x a year but the pipes outside of the unit have some buildup.
When moving some of the pipes due to other needs, the service found that the pipes had a significant amount of iron mud in them that you could scoop out with your finger.
How can I clean this out?
Thanks!
Mack56MUser is Offline
Hi, what about the amount of iron mud buildup on the pipes. Is it completely obstructing the water flow through the pipe? If the amount of buildup is too high it's better to replace the pipe with the new one or you can use a sewer snake and a garden hose to clear the water line pathway.
Membership Membership: Latest New User Latest: HotnCold New Today New Today: 0 New Yesterday New Yesterday: 0 User Count Overall: 34723
People Online People Online: Visitors Visitors: 141 Members Members: 2 Total Total: 143
