Posted By tinoue on 22 Jul 2010 11:28 AM
I'm sure it's an oversight given all the Q&A going on here, but in order to help you, we need your actual usage information in kilowatt-hours and CCF of gas (or whatever unit they bill you in). The dollar figure is more or less meaningless.
Most interested in man J calcs. I can at least figure out percentages with those. From the get, this thread has been packed with content void of substance.
At this point I'm not convinced anything is wrong. Just too little data.
Sq' means nothing without cu', dollars or consumption mean nothing without load calcs.
OP there is a thread at the top of this forum that says "problem with your heat pump start here" read it and fill in the blanks.
Employ brevity in responses. Answer our questions (took many tries to establish previous furnace was gas).
Not trying to sound terse, but we are now 3 pages deep without even establishing if there is a problem (comparing usage to load) aside from you may be short looped.
Part of the repair bids should show you what to expect when they are completed. What are the loads, what are the suggestions, what are the op cost projections.......?
To responders, did want to mention one thing. It was suggested that adding one loop would have little impact aside from raising ewt slightly. I submit that if 1 loop adds 20% to the field and if the ewt is currently so low in winter that unit is locking out on low temp, this "one" loop could have a very dramatic impact on performance.
IOW's each system must have at least "x" feet of loops to keep EWT above minimum in heating dominated clims. Once that is achieved I agree that adding even more than a little loop has very modest impact on op cost.
Joe
