Performance dropping
Last Post 20 Jan 2011 06:05 PM by Steve Dols. 24 Replies.
pomfreyUser is Offline
04 Jan 2011 09:12 AM
The reason I have a 2 pump flow center is that I was able to get that center for the same price as a single and even with just 1 pump running the flow was what I needed. I can turn on both pumps and purge the loop pretty good. With the latch relay circuit I figured the pumps would last a long time since they are alternating the work. Maybe not the best design in hindsight, but for the first 1.5 years the system has worked great! I have checked to see that only one pump is running at a time and that is the case. I have also slowed the flow to see what difference that would make and it made a 1 degree difference in the LWT but no difference in the temperature of the air being sent to the living space. I feel pretty confident that the field and pumps are not the problem ( My incoming water temperature is good). I think it might be time to have someone come and check the refrigent levels as you have suggested. Thanks for all your help and I will let you know what I find out.
Best,
hp
docjenserUser is Offline
04 Jan 2011 03:03 PM
Keep us posted. That is how we learn......
17 Jan 2011 05:14 PM
Doc,
It was a freon problem. 3.5 pounds of R410a and the system seems to be working well. I guess it  means that I have a leakand it will be a pain to find on this compact unit! Thanks again for your wisdom - HP
18 Jan 2011 08:04 AM
Bummer ' bout the leak. Good call Doc.
j
SteveUser is Offline
People Online People Online: Visitors Visitors: 262 Members Members: 0 Total Total: 262
