In an air-to-air system there is a condensate pan under the coils that catches the condensate during cooling that can be visually checked. In the unit you have I do not know how easy it is to check the condensate pan. However, if you have a condensate pump, then you should be able to tell if it is pumping condensate to the exterior during cooling. Try to trace the condensate drain to the exterior to see if any water is dripping from the line. This will give you some feedback but there is still a chance that some water is staying in the pan which might be supporting mold growth.
Maybe the experts will chime in and answer your question more directly than my attempt.
