Is the flowcenter neccessary?
Did you have another plan for circulating the fluid in the heat exchange loop?
Considering that you are on the raw edge of familiarity with a geo system, you might consider buying an all-in one kit. That way, you would have some minimal expectations that the components would all be compatible.
You also need to find a way to make sure that the system you are buying is properly sized for your heating needs. That would probably entail finding out what your heating needs are. You might ask the place you are considering buying the unit what resources they have available to analyze your home.
