Question on monitoring temerature and pressure drop
Last Post 01 Aug 2011 01:18 PM by waterpirate. 3 Replies.
steve_mnUser is Offline
01 Aug 2011 09:42 AM
Hi,
In the process of installing a 5 ton Climatemaster with hot water.
I have read about P&T ports and I wonder about the longer term, leakage etc, is that a concern?
If I go with P&T ports it seems to me they should be on the entering and leaving side of the heat pump as well on each side of the on demand hot water.
Should I also monitor supply and return air for the furnace, just holes in the ductwork for access?
Online sources where I can purchase gauges and P&T ports?
Comments?
thanks
Steve
01 Aug 2011 10:26 AM
Easiest thing is to purchase a hose kit that comes with ports and fittings as well as hose to come from flow center to heat pump.
j
01 Aug 2011 11:37 AM
Already have the hose kit, was part of the package.
waterpirateUser is Offline
flowcenterproducts.com
Roy Klaty
hope this helps
Eric
People Online People Online: Visitors Visitors: 164 Members Members: 0 Total Total: 164
