Posted By cook90 on 05 Sep 2011 10:20 AM
Background info: New construction home, lake loop, estimated EWT 90*F, Charlotte NC, 2 ton Climatemaster Tranquility 27 in walkout basement, 3 ton CM T27 on main level.
HVAC contractor is recommending the following desuperheater setup: The main level heat pump desuperheater routed to a buffer tank. The lower level desuperheater routed to the main tank. Why not run both systems through the buffer tank to recover the waste heat? Thanks.
You are right
Don't see any sense in that proposal, you are right to question that.
