We have a Waterfurnace Synergy 3D that I am trying to verify that it is running properly/efficiently.
For that past couple years we have had no problems with it, but I recently setup a home energy data logger and have been checking out the power usage of different equipment including the Geo unit.
From my observations, it appears that the Geo unit will start up on stage 1 and run for about 45 sec to a min and then kick into 2nd stage.
The system is setup mainly for hydronic floor heating but can run forced hot air if we choose. The thermostat is a White Rodgers (1F95-1277) and the way our contractor set it up, we turn on Heat on the thermostat but the temp set point will be lower than the house temp to prevent the forced air heating to kick on. But this allows the Geo to heat up the buffer tank that sends hot water to the floor zones. Then we can turn on individual zone valves with smaller thermostats in each room.
I've monitored the system for the past couple winters and noticed a pattern that did not seem right. The system will turn on and run for about 10-15 minutes and then shut down for about 5-10 minutes and turn back on and run for another 10-15 minutes. This continues to repeat throughout the day everyday.
It seems that it would be better for the system to run longer on stage 1 if possible.
http://img.photobucket.com/albums/v...efa68b.jpghttp://img.photobucket.com/albums/v...510a9f.jpghttp://img.photobucket.com/albums/v...6bfc27.jpgHere is a short snapshot of the energy usage, just was just for testing as we haven't needed to turn the system on yet this year.
http://img.photobucket.com/albums/v...e2218a.jpg
