Geothermal Heat Pumps
One ton unit installation
Last Post 25 Nov 2011 01:32 PM by
engineer
. 2 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
meat73
23 Nov 2011 12:19 PM
I bought a used 1 ton Geo thermal unit that was used by a REC for demonstrations at fairs. I have installed 700 feet of pipe in a slinky in the ground 6 ft deep. I brought the pipes into my garage and would like ideas on how to connect it to the unit. Build a flow center or use a purge cart that I have access to. I'm by no means a expert so try to keep it simple. Thanks for the help
waterpirate
23 Nov 2011 01:32 PM
If you have come this far, do the math for friction loss on your piping, calculate for 3gpm at the unit and build a non pressurised flow center out of a container, some plumbing bits, and the indicated circ pump. finished.
Eric
engineer
I won't argue with that advice - its a good way to get your feet wet as to geo...oops...bad analogy!
Don't forget anti-freeze if climate warrants
Membership:
croccohvacusa
People Online:
