Posted By dolphin on 19 Jan 2012 11:12 AM
I am hoping this is a basic question... Is there a recommended temperature to set my Waterfurnace Hydronic unit at, for a radiant floor application? If further information is necessary, I will do my best to provide this information (model number, size of home, pictures, etc.). Thank you?
Is it a water to water unit? or is it a SDV unit?
It's 120 degrees max. But i wouldn't even get close to 115 degrees for your unit's longevity sake. If it's a slab floor, then your in luck; your water should not be over 100 degrees if it is designed correctly.
