Posted By Alton on 22 Mar 2012 08:22 PM
Will a deep well that equals two shallow wells require more pumping power?
It ain't the depth, it's the geometry/topology. Two short loops
of pipe connected in series are no different than a single loop
of twice the length. However, if you connect the short loops
in parallel, it's an entirely different situation -- requiring less
pumping power for a given pipe diameter (and a given GPM).
It doesn't matter in the least whether the pipes are vertical or
horizontal.
Looby
