To be sure, there would be that concern about freezing the drain in some circumstances. However, if there typically is ground water flowing into the drain all during heating season, however slowly, that flow constitutes a heat source, much like the use of "bleed" in a standing column well design for heat recovery. I suppose ocho's answer depends on how continuously the drain is expected to flow. |
