Desuperheater pump?
Last Post 03 May 2012 08:30 AM by joe.ami. 6 Replies.
GregwUser is Offline
02 May 2012 12:05 PM
I have a climate master HP without a built-in desuperheater pump, it has the in / out ports, but I need separate pump unit. The only one I can find is a Bard unit at like $800, which seems crazy high. Anyone have a source for such a pump kit? Thanks
knotETUser is Offline
02 May 2012 12:11 PM
Manufavcturers have 33w to 180+ bronze pumps on line
TACO and Armstrong and Grundfos and B&G air and wet rotor and variable Grundfos and WILO for most of those applications. Perhaps see if who sold the unit to you will give you a climate master tech number or etc. Those pumps are replaced by their OEM sales and probably have a plan to follow for you.
02 May 2012 02:32 PM
It's not just a pump, it's the controls and temperature sensors that make up the whole unit.
docjenserUser is Offline
02 May 2012 06:28 PM
What model heat pump do you have?
02 May 2012 10:27 PM
along docjensers lines, i thinke as written, the OEM will have a plan for you , with a plan of those sensors greg references...
03 May 2012 05:42 AM
I have a 2 ton commercial line unit that did not have a built-in desuperheater pump. It was part of a much larger order on a commercial project and they added one extra HP for me, got it at below cost.
Any cir will do but u also need temp control. The bard has both but is plumed in half inch OD. Was not aware CM had DSH package witout circulator.
People Online People Online: Visitors Visitors: 197 Members Members: 0 Total Total: 197
