Greetings.
I have a new WaterFurnace NDV049 connected to two vertical closed-loop wells. After the installation, the system made a thump-thump-thump sound (3 or 4 loud, rapid thumps) when shutting off after a heat cycle.
The installer first suspected air in the pipes. But after hearing the thumping, he said it sounded like something else. He tinkered with the system, and the sound went away, though he said he wasn't sure of the cause.
After the system ran quietly for several weeks and then sat idle for a while, the thumping is back. Any ideas what might be the cause?
