GSHP on Second floor
Last Post 08 Aug 2012 10:42 PM by whirnot. 14 Replies.
whirnotUser is Offline
06 Aug 2012 03:32 PM
In order to be more space efficient, my Architect is proposing we put the mechanical room on the second floor. I am planning a GSHP but have no experiance with one. I notice the Manufacturer recommends they be placed and a Vibration isolating pad, except for the bottom discharge units. I have to assume there is a significant amount of vibration/ noise in the unit to need this.
Am I looking for trouble placing it on the second floor? If not should I use a rear or top discharge so it may be placed on a pad?
06 Aug 2012 09:06 PM
I would strive to avoid locating a compressor in a second floor mech room - vibration isolation pads can only do so much, and harmonic frequencies of floors and walls are difficult to predict.
There is no problem putting an air handler upstairs. Consider a split system if necessary - locate the compressor section (a cube roughly 2x2x2) somewhere noise and vibration won't be a concern
Bill NeukranzUser is Offline
06 Aug 2012 10:56 PM
My two WaterFurnace 3 and 5 ton 2 stage variable speed geothermal units are suspended above the attic floor, hanging from the roof rafters.  No compressor vibration noise at all.
06 Aug 2012 11:12 PM
Fair point.
The rafters' separation from rooms ceilings and walls or the hangers themselves may serve to isolate compressor vibration from occupied spaces, but I'd be reluctant to bet on that favorable outcome if I could possibly avoid rolling those dice in the first place.
06 Aug 2012 11:30 PM
I think it's due to the pitch of the roof.  The four each steel rods are at least 20 feet that are suspending the Envision units a couple feet above the attic floor.  I think the rods are absorbing the vibrations.  Bill
07 Aug 2012 08:26 AM
That's a heckuva attic!
ChrisJUser is Offline
07 Aug 2012 01:12 PM
Bill,
Sent you a PM
ChrisJ
07 Aug 2012 03:39 PM
Posted By Bill Neukranz on 06 Aug 2012 10:56 PM
If the location proves to be advantageous for other reasons, that is an option to consider. I have used threaded rod with Vibration isolators with high vibration equipment in the past, and they were very effective. More so than surface mount.
08 Aug 2012 12:22 AM
Here's an image showing the suspension .
Envision unit is sitting on two 4x4 cedar blocks inside a water pan.  Water pan is suspended about two feet above attic floor via 4 threaded steel rods connected to roof rafters.  Each rod is about 20 feet.
08 Aug 2012 12:35 AM
Posted By ChrisJ on 07 Aug 2012 01:12 PM
Bill,
Sent you a PM
ChrisJ
Chris, location of my system description is here: http://www.neukranz.com or http://www.welserver.com/WEL0043 .
Also, even more detail can be obtained from here:
Alot more detail (my solar tour reference guide): http://www.txses.org/NTREG/dnld/201...ukranz.pdf
A speech I gave with a lot of detail on GSHP system: http://www.txses.org/NTREG/dnld/201...20Club.pdf
And another speech I gave with a lot of detail on monitorining: http://www.txses.org/NTREG/dnld/201...toring.pdf
Hope these contain what you're looking for.
08 Aug 2012 09:31 AM
Bill,
The pbase gallery is what I had seen before, thought it would be useful for whirnot.
Thanks for all the links, ChrisJ
08 Aug 2012 09:33 AM
It depends on the attic, but our last situation had a unit behind a knee wall that barely fit to begin with and I think all wished it had been a split system at the end of the day.
j
08 Aug 2012 10:57 AM
And Joe breaks the record for the number of repeated postings! (now edited out).
08 Aug 2012 11:14 AM
Posted By jonr on 08 Aug 2012 10:57 AM
It's been a long road. I'm just happy to bring another gold medal home to the US!
Posted By Bill Neukranz on 08 Aug 2012 12:35 AM
Bill,
Sent you a PM
ChrisJ
Wow Bill, What a ton of data!  I can certainly see your purpose of all the energy upgardes I cannot imagine utility bills such as those.
We are planning to go net zero, as we are not happy with our total Ave Of 435 KWH per month, and $18 gas bills.
But we have made a lot of strides to get there.
People Online People Online: Visitors Visitors: 252 Members Members: 0 Total Total: 252
