Geothermal Heat Pumps
filtration scheme for lake water pump and dump?
Last Post 15 Aug 2012 12:00 PM by
. 3 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
contender
13 Aug 2012 05:11 PM
ok, so ya don't want minnows swimming in to get ground up by the pump, so so some variety of foul-proof intake seems a given.
and the other water filter inside ought to be such that little maintenance is required. ( heck, you can't get people to change their furnace filters.)
so, has anyone done this? guess a cupro-nickel exhanger would be required. but getting a low-cost install like this sure is tempting!
contender
14 Aug 2012 08:00 PM
and what would happen if the coax gets silted up? (in spite of your elegant, assiduously-maintained filtration scheme)
engineer
15 Aug 2012 11:33 AM
Include isolation valves and hose bibbs or boiler drain spigots for flushing.
I wouldn't hesitate to try this, conditions permitting, on a personal property
I'd be loath to risk a customer on it unless they were truly on board for the inevitable monitoring and maintenance.
The volumes of water needed are immense, so the filtration scheme needs high capacity
Can you account for change in lake level such as during flood, drought, or dam release?
Yes, you should be able to find numerous reference systems.
Membership:
croccohvacusa
People Online:
