I live in Michigan and am considering a closed-loop 4-ton system and want opinions on slinky pipe in trenches vs horizontal drilled straight pipes with a u-bend at end. I have plenty of space and mostly clay soils. I am willing to pay extra to avoid the mess of trenches and to have the lines drilled to the house (I don't want to tear up my landscaping).
The directionally-drilled systems seem to mostly use one-loop of pipe per ton, with each extending 220 ft out and then connecting with a U-bend and returning in a pipe right next to the pipe going out. Thus, unless one of the two pipes is smaller diameter so coolant is running faster one way than the other, it seems that the fluid coming back would be warmed or cooled by the fluid flowing out. Just to be clear here--the coolant travels out in winter and is gradually warmed by the earth around it as it flows to the furthest point out (220 ft), but then as it returns to the house it gets cooled back down by the outflow. So the warmest soil in winter is the very end of the 220 ft and then the pipe comes back through the coldest soil. This countercurrent flow system is how a bird's legs work and it is an efficient system if you want the extremities to be at a different temperature than the core.
It seems like it would be more efficient to run the pipes out, even as double lines, and then connect them to return lines that come back separately and several feet away from the outflow lines.
Can someone comment on this?
