Total cost/kwh charged to Home Owner/paging Bill Neukranz
Last Post 25 Sep 2012 09:14 PM by engineer. 3 Replies.
Time outUser is Offline
24 Sep 2012 05:42 AM
......... Starting a "New Topic"
Bill NeukranzUser is Offline
25 Sep 2012 03:06 PM
I'm here today.  How can I be helpful?
25 Sep 2012 03:52 PM
If you're looking for an historical perspective of electricity grid rates in the Dallas area for the past 5 years, it's one of the 4 historical charts at
http://www.welserver.com/WEL0043 .  For 2011, grid rate averaged 9.9¢/kwh.  This year so far, for past 12 months, the grid rate is down, averaging 9.0 ¢.
If you're looking for an historical perspective of what it costs to cool & heat a 3400 sf single story structure using geo, there's a Monthly Cost chart at the same above reference.  Right now, the rolling 12 month average for heating and cooling, per month, is $47/month.  This assumes the electricity is all coming from the grid, with no solar PV contribution.  This is down quite a bit from last year's 2011 average of $62 because Winter low temps and Summer high temps this year have not been as extreme as last year.  And, a grant was obtained to add attic insulation recently.
If you're looking for kWh consumption for heating & cooling, using geo, it's currently at 520 kWh/mo, or about 17 kWh per day.  I don't have a chart showing this.  Again, this is down quite a bit from last year.
Lastly, if you're looking for analysis of heating & cooling cost, using geo, indexed to make it an apples to apples comparison regardless of weather, climate, area lived, and/or size of structure, there's a Structure Energy Efficiency Performance chart at the same URL noted above.  For 2011, the structure's energy efficiency performance for cooling was 7.0 BTU/CDD/SF, and for heating was 2.4 BTU/HDD/SF.  For 2012, these numbers will be improved, due to taking advantage of a govt grant that added insulation to the structure.
Hope this helps.
FWIW, another data point, but without nearly as many bells and whistles as Bill...
Our 3400 SF ICF / Sprayfoamed attic home completed in 2008 has a base load of about 7500 kWh / year and an annual heating / cooling usage of 3000 kWh for a total cost, in 2011, of $1200. Loads include well and septic pumps (in lieu of water and sewer utility charges)
The house is near Jax, FL, has a single Waterfurnace Envision 3 ton package unit fed with open loop artesian well water, EWT 71. Heating setpoint is 71 Cooling setpoint 77. House leaks 1600 CFM 50; about 3.5 ACH 50...good but nothing spectacular.
Hope that helps
People Online People Online: Visitors Visitors: 163 Members Members: 0 Total Total: 163
