Geothermal stealing from water softener?
Last Post 27 Nov 2012 10:00 PM by J Miley. 10 Replies.
evelkneeUser is Offline
29 Oct 2012 05:27 AM
With nothing using water in my house besides my geothermal unit running, My water softener shows there is water going through its meter. This is strange because the only way this could be happening is if my geothermal is pulling water and causing my water softener to reverse flow. It turns out to be about .5 gallons a minute, that my geo is leeching from my water softener. Has anyone else had this problem?
29 Oct 2012 10:14 AM
If there is reverse flow, you can install a check valve.
29 Oct 2012 10:17 AM
is this an open loop?
29 Oct 2012 11:05 PM
Yes this is an open loop.
I actually received a call from a retired plumber who works with the manufacturer of the water softener. He gave me a couple of options. 1st, since he doesn't think the geothermal is actually using the soft water, but instead, the changing of the pressure in the house is causing the water to move back and forth when the pressure drops and when my water pump kicks on, he said I can over ride the metered softener and just soften my water every 3 or 4 days instead.
2, install a check valve on the inlet to my water softener, but he said I must also install a heat expansion thing on the inlet of my water heater.
3, get a new constant pressure water pump. About $3000
My idea is maybe purchasing a small inline constant booster pump that I can install in front of my water softener. Set it at 60 psi and enjoy the constant pressure at all my faucets. I'll have to check cost for this options
Thanks all who responded.
waterpirateUser is Offline
30 Oct 2012 08:30 AM
Option # 3 will be the most expensive check valve you ever purchased. Correct diagnosis is the best course of action here, or you are throwing solutions at a problem you may not have. Isolation valves, check valves and T eeing in some pressure and vacum gauges will give you a garaunteed dignosis.
YMMV
Eric
CalladrillingUser is Offline
30 Oct 2012 08:52 PM
although i am a big fan of the constant pressure systems from Grundfos with the CU-301 controllers, i do believe it may be overkill ( until a new water pump is needed). This could be something as simple as a very small leak in a toilet, a stuck valve inside the water softner itself that is flowing to drain. Install a check valve on the inlet and call it a day. What brand water softner do you have?
Dan Callahan
Www.CallahanWellDrilling.com
30 Oct 2012 11:34 PM
Before casting about for solutions, be certain you actually have a problem.
31 Oct 2012 02:27 AM
The water softener uses the Clack ws-1 valve. The problem is when the geothermal is running, my water softener is showing it is being used. This also happens if I open up the valve that is by my storage tank and I dump water in my sump pump. It is pulling water through my water softener in reverse.
If I turn off my Geo, the water softener works fine. There is no leak, or water flowing through the meter.
31 Oct 2012 10:41 PM
Go for the check valve(s)
jokinUser is Offline
03 Nov 2012 11:59 PM
I was glad to read this thread.  I just noticed this problem on my open loop setup with a watersoftener with the same Clack WS-1 valve (it was reading 0.3 gpm).  I have the Franklin Electric variable speed, contstant pressure system so I'm guessing that might not be a solution for you.  I think its more how the water softener and geo unit are piped... how close, etc...
I'm going to make a note to install a check valve when I get a chance!
J MileyUser is Offline
Put the expansion tank on the cold side of the water heater. Where I live we need regulators and check valves on every thing, to help control high pressure surges from water company. If you install the expansion tank it will extend the life of your water heater, maybe double or triple it. Most all regulators have built in check valves if you block the pressure you need to control it. They are often $100.00 or less on Ebay. J Miley Lived not your usual life
People Online People Online: Visitors Visitors: 315 Members Members: 0 Total Total: 315
